2020-08-26
11:18 AM
2021-09-15
12:47 AM
Noemi Balogh
2020-08-26 03:43 PM
2020-08-27 03:16 AM
Kristian wrote:None actually, haha.
what file type are you opening to extra the data?
2020-08-27 05:16 AM
2020-08-27 05:21 AM
Ralph wrote:Hi Ralph, thanks for tuning in!
In what context will the GDL add-on be called, e.g. within the parameter script? This is important because you can't really make any parameter changes outside of that scope.
2020-08-27 07:38 AM
2020-08-27 10:37 AM
Ralph wrote:Are you sure that this is the way? I couldn't get it to work in my tests. If there was an empty dynamic array passed to the GDL add-on it refused to return anything.
Could you simply define an empty array in the GDL script
2020-08-27 10:48 PM
2020-08-28 02:58 AM
runxel wrote:We are eliminating the use of GDL add-ons from our toolset because they cause too many problems for customers. But from previous tools, we did the following in GDL (rough pseudocode):
If I try to access the array in GDL again it always says "out of bounds" which means there is nothing in there.![]()
dim incomingValues[] rowCount = 0 colCount = 0 unused = input(presetChannel, "Get_Array_Par", "requiredParameterName", rowCount, colCount, incomingValues)…and the following in the addon (again, rough pseudocode):
GSErr __GDLEXT_CALL InputFromDataFile(Int32 channel, GS::UniString const &recordID, GS::UniString const &fieldID, Int32 inCount, Int32* outCount, GS::Array<GdlValueRecord> &values, GS::Array<GS::UniString> &strings) { //...code to define rows, cols etc here *outCount = rows * cols + 2; values.SetCapacity(*outCount); GdlValueRecord rowRecord, colRecord; rowRecord.SetLong(rows); colRecord.SetLong(cols); values.Push(rowRecord); values.Push(colRecord); for (…however you iterate through your array data) { GdlValueRecord record; switch (…whatever data type…) { case intType: record.SetLong(…int value…); break; case realType: record.SetDouble(…double value…); break; case strType: record.SetString(…next string index…); strings.Push(…string value…); upto++; break; } values.Push(record); } }This is a bit rough, but might point you in the right direction. Depends a lot on what you want to do.
2020-08-28 11:00 AM
