Archicad C++ API
Zone Areas
poco2013
Mentor
Is there any way to obtain the measured and calculated areas of Zones using the API. I can obtain the zone structure of 'API_Zone_Type' for each zone but it does not appear to contain a area parameter.
Need to compare zone areas to obtain FAR's and other factors and would prefer to do it within a "Add-on'. if someone could point me in the right direction?
Gerry
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
You can retrieve the calculated quantities of an element using ACAPI_Element_GetQuantities function.
This function returns the area of the given zone:
double GetAreaOfZone (const API_Guid& zoneGuid)
	API_ElementQuantity	quantity = {};
	API_Quantities		quantities = {};
	API_QuantitiesMask	mask;
	ACAPI_ELEMENT_QUANTITY_MASK_CLEAR (mask);
	ACAPI_ELEMENT_QUANTITY_MASK_SET (mask, zone, area);
	quantities.elements = &quantity;
	ACAPI_Element_GetQuantities (zoneGuid, nullptr, &quantities, &mask);
	return quantity.zone.area;
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
poco2013
Mentor
Worked perfectly - Completely missed this.
Thanks
Gerry
