Archicad C++ API
access custom image in carpet object
Hi all,
how to access the "use image" option inside the Archicad carpet object for example? See image for details.
Whe I access the Material using ModelerAPI, Archicad tells me, that there is no texture inside this material. My method is working fine with other elements like walls where I get the texture, if there is one:
ModelerAPI::Material material;
polygon.GetMaterial(&material);
if (material.HasTexture()) {
    ModelerAPI::Texture texture;
    material.GetTexture(&texture);
Thanks
Source
1 REPLY 1
Peter Baksa
Maybe a late answer helps others:
The Carpet object builds a model with a blank white material, and displays a picture independent from the material (picture GDL command).
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
