Using the Railing tool and Gdl to link soffit and fascia to roofs.
Still Learning how to manhandle the railing gdl, but im getting there. https://youtu.be/Rs3gBaFHgOo Downloadhttps://bit.ly/BIMRithmSoffitandFascia
I'd like to replace an element that actually is a window by a door, by changing the used library part.For replacing library parts window with window or door with door it works perfectly.But is it possible to change an element from window to door?My a...
Please Teach me. How To Hook And Cancel When Delete Element. I catch DELETE Handler static GSErrCode __ACENV_CALL ElementEventHandler(const API_NotifyElementType *elemType) { GSErrCode err = NoError; switch (elemType->notifID) { case APINotifyElement...
This is a cross section.The left insulation mark is a slab.The insulation on the right is a slab in the GDL.Why is the GDL slab not expressed as a fit for insulation?Is it possible?
Hello! The curtain panels are really versatile and I use them to make continuous cabinet doors, but I have a problem: I want to insert a handle on each CW door just in one side only. Will it be easy to configure in GDL (CW Door 25.gsm), or should I p...
1. I've been having a lot of problems with Archicad. I'm working on modeling a project whose file is 552.8MB which is very BUG, forcing me to restart the file several times during work, which becomes very stressful and implies a loss of time in the...
Hello, I am trying to create an object which is essentially a 4 sided shape where the 4 corners can be moved which is simple enough on it's own. However there is also the requirement to have the option of adding a fillet or chamfer to each corner. Is...
Hello, I have some weird problem with a dynamic hotspot. I'm on AC 21 3005 but I replicated it in AC 24 7006 too. It's not a really important bug but I cannot understand what is happening So let's say I have an object with two extrusions, in the main...
I've tried scripting the same tubular shape using "tube" and "sweep." Both results are not completely as desired due to the lines appearing in 3D. Is there anyway to eliminate these lines? resol 32 sweep 2,36,0,1,1+2+16+32, 0,0,901, 1.5",360,4001, 0,...
Hi, I'm trying to extract some .gsm to .xml using the LP_XMLConverter tool on my M1 Pro (running Monterrey 12.2.1). I've been trying with AC 21 or 24 and have had the same error every time :zsh: permission denied: /Applications/Graphisoft/Archicad XX...
User | Count |
5 | |
5 | |
4 | |
3 | |
3 |
