Developer forum
gdl unit of text
lmcardoso
I am a newbie in coding. sometimes i try to cook something but i end up spoiling the broth. i spent the last 30min reading the gdl editor on strings and integers but that thing is way to complex for me.
I am trying to change the units of the value of AxB but i cant seem to find it.
this is my object and now the area, which is no more than AxB is in millimiter but i want it in meters
this is my code
set line_type ln01
pen pen01
fill fill01
poly2_b{5} 5, 3, 0, pen01, pen02, pen03,
0, 0, 1, 0, 0, 1, 0,
0, 0, 1,
A, 0, 1,
A, B, 1,
0, B, 1,
0, 0, 1
define style{2} "AC_STYLE_1" "Arial", txsz , 0
paragraph "AC_PRG_7" 2, 0, 0, 0, 1
pen 1
set style "AC_STYLE_1"
""+"< "+STR(1000*A,1,0)+" >"
endparagraph
textblock "AC_TEXTBLOCK_7" 0, 5, 0, 1, 1, 1,
"AC_PRG_7"
richtext2 A/2, .2, "AC_TEXTBLOCK_7"
paragraph "AC_PRG_8" 2, 0, 0, 0, 1
""+"< "+STR(1000*B,1,0)+" >"
endparagraph
textblock "AC_TEXTBLOCK_8" 0, 5, 90, 1, 1, 1,
"AC_PRG_8"
richtext2 0.2, B/2, "AC_TEXTBLOCK_8"
IF txt01=1 THEN
DEFINE STYLE TEXT_1 Arial, txsz , 5 , 0
SET STYLE TEXT_1
TEXT2 A/2, B/2, ""+STR(1*A*B,1,0)+"m2"
ENDIF
Can anyone help me please?
p,s, yeah i guess my code is super complicated ahaha
ArchiCAD 23/24/25 with Win 10
DGSketcher
@lmcardoso metric GDL coding is in meters by default, so you text should be...
TEXT2 A/2, B/2, "" + STR((A * B), 8, 3) + "m2"
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
11 REPLIES 11
SenecaDesignLLC
you need to use STR{2} so you can set what you are after.
also  you dont need the "set" for line_type or style to work.
FREE wall Accessory framing and coverings
bit.ly/BIMRithmWallAccessories
FREE Truss object.
https://bit.ly/BIMRithmTrussV1
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
lmcardoso
thanks seneca, but for me that is still unknow to me.
i tried TEXT2 A/2, B/2, ""+STR{2}(1*A*Bsqm,1,0)+"m2"
but it doesnt work...
If you share the object I can help ya get it to work.
FREE Truss object.
lmcardoso
thanks a lot!! i really appreciate it
SenecaDesignLLC
so maybe i am miss understanding, but if you change the code to
TEXT2 A/2, B/2, ""+STR(1000*(A*B),1,0)+"m2"
does this not get what you want?
FREE Truss object.
lmcardoso
i tried but that no it doesnt solve the problem. I guess its the units that are not right
what it should appear is 10,8m2 instead of 10800.
on your left a fil showing the area and on the right my object
okay try this
TEXT2 A/2, B/2, ""+STR("%.3m",(A*B))+"m2"
FREE Truss object.
Another way, with reading the working units of the project
format_string = "%.0" !Defult
n = REQUEST ("Area_dimension", "", format_string)
!! Or
!!n = REQUEST ("Calc_area_unit", "", format_string)
_stUnit = "m"
if strstr (format_string, "mm") & not(_bUnitIsFound) then
	_stUnit 	= " mm"
	_bUnitIsFound  	= 1
endif
if strstr (format_string, "cm") & not(_bUnitIsFound) then
	_stUnit 	= " cm"
	_bUnitIsFound  	= 1
endif
if strstr (format_string, "m") & not(_bUnitIsFound)  then
	_stUnit 	= " m"
	_bUnitIsFound  	= 1
endif
if strstr (format_string, "f") & not(_bUnitIsFound) then
	_stUnit 	= " ft"
	_bUnitIsFound  	= 1
endif
if strstr (format_string, "i") & not(_bUnitIsFound) then
	_stUnit 	= " inch"
	_bUnitIsFound  	= 1
endif
_stUnit = _stUnit + "²"
area_ = A * B
area_txt = str(format_string, area_) + _stUnit
https://github.com/kuvbur
This is a great answer if you're trying to accommodate multiple different disciplines!
FREE Truss object.
DGSketcher
lmcardoso
thanks everyone for the input and solutions. it works now !!! wayayayayay
