Archicad C++ API
layoutinfo. customData give me bundles of guid - >value but where do I get a bundle of varname->guid
User was create new variable in master layout.
I need to get value of that variable by name.
But I have only pairs guid->value in the layout.customData.
How I can get values by variable name?
In original example Database_Control.cpp there is a no informative code how to change all variables:
API_LayoutInfo	layoutInfo;
BNZeroMemory (&layoutInfo, sizeof (API_LayoutInfo));
if (ACAPI_Environment (APIEnv_GetLayoutSetsID, &layoutInfo, &api_dbPars.databaseUnId) == NoError)
      for (auto it = layoutInfo.customData->EnumeratePairs (); it != nullptr; ++it)
                   *it->value += " - Modified via API";
      ACAPI_Environment (APIEnv_ChangeLayoutSetsID, &layoutInfo, &api_dbPars.databaseUnId);
My code is:
err = ACAPI_Environment(APIEnv_GetLayoutSetsID, &layoutInfo, &databaseUnId, &actualPageIndex);
if (layoutInfo.customData != nullptr)
       if (layoutInfo.customData->GetSize() > 0)
             Guid keyguid;
             keyguid.ConvertFromString("7151E155-1B9B-4F17-9D4F-35F8036DE4A2");
             API_Guid key = GSGuid2APIGuid(keyguid);//layoutInfo.customData->GetAKey(0);
             UniString us;
	     if(layoutInfo.customData->ContainsKey(key))
                   us = layoutInfo.customData->Get(key);
As result - us contains value.
But I need to get it by layout custom variable name;
Oleg
I didnt try, but I guess you need function:
GSErrCode ACAPI_Database ( APIDb_GetLayoutBookID, API_LayoutBook* book );
and field
book->customScheme
Oleg
and field
book->customScheme
It works great!
Thank you very much!
