You can just type the web link as text.
When you publish as a PDF it will become a hyperlink.
The problem is you can disguise the link text as some other abbreviated text.
I guess a trick might be to type the web address with white text so it doesn't print and then place the abbreviated text over the top.
I just tried and it works but I found I had to bring the abbreviated text forward in the display order, otherwise it truncates the web link.
I also like to use QR codes because they even work from paper plans.
Just scan with your phone and you can access whatever the QR code is linking to.
