GDL
simple way for knowing, what level is the insertion-Level of an library-part?
Hmooslechner
Now, i am on an GDL for a Stairway for all levels of a building at once.
I would like to script a kind of error-message that the User is informed, to insert it at the cellar, the 0-Level in Archicad, but i didnt find a simple way to get the internal Info, in which Building-Level-Number the project, this GDL is really inserted by the User.
Dont tell me about GLOB_HSTORY_ELEV and so on.. -i have tried it without some success..
I just want the user to know - "You inserted it in the wrong Building-Level - delete it and put it in the deepest."
Maybe, it would be better to automaticly insert it "right".. Have to think about it..
Its something like this:
5 REPLIES 5
Hi Hmooslechner,
If I understand you correctly, you can trigger a GDL Print Message when the user makes an improper entry.
Hope this helps.
This is just off the top of my head.
Could you use ...
n = REQUEST ("Story_info", expr, nStories, index1, name1, elev1, height1 [,index2, name2, ...])
to get all of the storey info.
An example from the GDL manual ...
DIM t[]
n = REQUEST ("STORY_INFO", "", nr, t)
FOR i = 1 TO nr
nr = STR ("%.0m", t [4 * (i - 1) + 1])
name = t [4 * (i - 1) + 2]
elevation = STR ("%m", t [4 * (i - 1) + 3])
height = STR ("%m", t [4 * (i - 1) + 4])
TEXT2 0, -i, nr + "," + name + "," + elevation + "," + height
NEXT i
Determine which storey has the lowest elevation and then compare that to the home storey of the object.
If they don't match then print your warning.
But that assumes you want to actually place it on the lowest storey - that could be a dummy storey.
Only you will know if that is a solution for you (i.e you never have lower dummy storeys).
Podolsky
Ace
In the earlier versions use of PRINT in GDL did create additional warning window. But now by default all GDL warnings are in Session Report, that user is not usually looking at.
Maybe you can type message directly on the object (as soon as object needs to be deleted - the message on the floor plan is not bad idea).
You also can try this method - I guess your stair is floor sensitive already and shown on all floors - just shift Z of the stair to the position, where it needs to start (for example ADDZ -GLOB_ELEVATION-GLOB_HSTORY_ELEV), then it doesn't really matter on which floor it was placed initially.
Hmooslechner
Thanks - i did it this way and in 3D its working fine.
n = REQUEST ("STORY_INFO", "", nr, t).   !! from GDL-reference..had this anyway in the masterscript..
FOR i = 1 TO nr
	nr = STR ("%.0m", t[4 * (i - 1) + 1])
	name = t[4 * (i - 1) + 2]
	elevation = STR ("%m", t[4 * (i - 1) + 3])
	height = STR ("%m", t[4 * (i - 1) + 4])
	Geschosshoehe = t[4 * (i - 1) + 4]
		Geschosshoehen = Geschosshoehe
NEXT i
!! This puts it in the right hight, no matter where its inserted in the Project.
ADDZ -GLOB_HSTORY_ELEV-Geschosshoehen[1]
In 2D, i still have some problems to solve, but this is my task now.
Here in Austria, its normal to have cellars below zero, but elswhere it could be different and my GDL needs a story below zero. Otherwise its making silly things. More brainpower to use - hope its there in me..
Thank You all!
Here is a link to all my stairs and railings, probably some useful things
https://bit.ly/3yKvn7q
