Archicad C++ API
the file is an outdated add-on that cannot be used with this
hello,
everytime I try to load a simple add-on with AC13 I get this message:
"the file is an outdated add-on that cannot be used with this archicad version"
I tried everything.
11 REPLIES 11
I figured it out!
I found out that when I launch AC it writes: "document version: 13.003"
So I changed the version def in the src code and it worked
thanks ralph!
I have the same problem with the DG_Test example.
Where did u change the AC version number?
I'm using visual studio 2005 with a 64bit windows 7 and AC 14
Marco
