A zone stamp of "거실(living room)" appears outside the detail tool border.
LeeJaeYoung
I'm not concerned with the detail tool borders and zone stamps, but by the zone? Or is it a bug?
Q2.
There is Model View Options in Settings.
But when I rebuild, the option doesn't seem to work. Where are these settings available?
Q3.
Where can this be used?
Does it disappear when you click on it?
Q4.
How do you make the parent body of detail?
It seems to me that you have to do it after adjusting the environment every time you rebuild. Is this correct?
I thought that it would be possible to set the environment in the detail view and load it, but that doesn't seem to be the case.
AC27 on window 11
I can't understand what is surprising you?   The zone stamp is fixed in its 2D location... which you have total control over (you can drag it wherever you want it to be).  In the case of your detail, your detail border does not include the zone stamp, so it will not appear in your detail.
I may not be understanding you - much of what you post does not make any sense to me - and so recommend that you contact your normal technical support channel, which is your local distributor of Archicad.
One of the forum moderators
sorry. ^^
If you tell me how to control it, I think I can understand. There are very few places in Korea that use Archicad, and if you want to study, you have to study only through YouTube and manuals like me. The cafe was also discontinued a long time ago and is not responding.
Are you a YouTuber?
I'm also studying with your videos.^^
I don't want to delete it.
If you rebuild model, it will come back to life?
AC27 on window 11
