AC 19 Labelling Walls
fuzzytnth3
In the olden days of ArchiCAD 18 and back into the mists of time elements such as Walls could be "Auto Labelled" but now with AC19 that little button has gone which means if I want a floor plan of walls with their IDs labelled I can't just click the "Auto Label" button and label a couple of hundred walls.
Or can I???
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Eduardo Rolon
read here
http://archicad-talk.graphisoft.com/viewtopic.php?t=49612&start=0
recommended to also read the Manual since Labels were updated for AC19
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
fuzzytnth3
Nah ha excellent thank you I knew there would be a way but my searches in the manual were using the wrong terminology. Also my Work Environment was also messed up so the menu item wast there [headslap]
Ta again
