AC 23 Beam Section Cut Pen
Brad Elliott
I am cutting sections through my model and the complex profile beams are all cutting with the same black pen (1?) and I can't find where to adjust it in the beam settings, section settings, model view options, graphic overrides, or renovation filter. I'm guessing I've missed a couple of other places I can check and am reaching out for help. How do I set the section cut pen?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
James B
The Cut Pen is defined by the Complex Profile - right click and Edit Selected Composite/Profile.
Select the Fill, and edit the outline Pen of the Fill.
Same for Composites, they are defined by the Attribute.
James Badcock
Graphisoft Senior Product Manager
Brad Elliott
Thanks James, The last part which I am adding as a reminder to myself when I look this up again in the future is it is the fill in the info box and not the cut end lines in the actual Profile Manager box.
M1 Macbook Pro
