AC 26 MacOS Ventura Apple Silicon Bugs
EH21
Where can we report bugs? I keep running into issues after recently changing my entire setup. I was on AC22 on a 10-year-old mac and moved to AC 26 on a Mac Studio M1 Max. I'm now missing my old machine. Even though it was slow, I could at least do things! If anybody can point me where to go or if you know of solutions to any of these issues, please let me know.
1 - Line Tool - cannot select different line type or change line type once drawn
2 - Rendering with Cineware Maxon - it will not render when the "sub-polygon displacement" setting is turned on
3 - Archicad crashes every time I try to use "Page Setup"
4 - 3D views appear grainy/low-res. Everything else on my computer is 4k resolution and performs fine. It's just within the Archicad window that 3D views (non-rendered) appear low-res
4 REPLIES 4
Lee Hankins
If you search for ‘Ventura’ there is an article explaining some of the issues.
https://community.Graphisoft.com/t5/Setup-License-articles/macOS-13-Ventura/ta-p/359447
Y
ou can select the line type using the arrow keys on the keyboard as a workaround. The other issues you mention, I haven’t come across. The page setup could mean your printer driver needs to be updated to a Ventura compatible version.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
The answer to that is the same as it has always been: your local technical support.  Since you are running the USA version, that would be Graphisoft North America in Massachusetts.
https://graphisoft.com/us/contact-us/local-contacts
Reporting here can be helpful to others, and allow others to attempt to reproduce your issues though.  So, consider doing both. 🙂
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Lee Hankins
Update for Silicon and Intel for Ventura has been released.
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-26-macOS-13-Ventura-compatibilty-up...
Lee Hankins
macOS Tahoe (26.0)
Robert Nichols
I'm suffering the Page Setup crash as well. Total mayhem. I've resorted to creating a publisher set for everything, as that, somehow, just works with the Master Page settings. Then I print the resulting PDF. But would love to have proper functionality back.
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
