Document & Visualize forum
AC17 Element ID Manager - Resequencing IDs issue
MarkMoscrip
In AC 14 and prior, the Element ID Manager (EIDM) had the ability to
renumber ID's in any order you wished. For example you could pick every window
in counterclockwise sequence and use the EIDM to quickly reset the ID's in a
counterclockwise sequence.
However in 17, while you can change the ID's with EIDM, you can no longer
choose your sequence direction. The order in which you choose the windows no longer
changes the sequence. It appears clockwise has become the default.
Can GS look into this and rehabilitate the Element ID Manager's re-sequence ID
functionality to follow the users' selection sequence?
Thank you,
Mark
Mark Moscrip
AC-18 USA 5100 <-- AC-9, Win7Ult
12 REPLIES 12
It works for me.
I selected 5 Walls, the ID of all of which I set to "SW - 000"
Then I selected then in this sequence: 3rd (from left), 4th, 5th, 1st, 2nd.
Went to the Element ID Manger Dialog, set Element Type, to Wall, Chose Element ID for Selected Criteria and selected the Unique ID for Each Element radio button. Set ID format to "W-001".
The IDs of the five selected Walls were changed to "W-001" to "W-005" in the sequence I selected them. So for me it works as it did in previous versions.
This is in AC17 INT.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
MarkMoscrip
Thanks for looking into this for me, but I'm still getting poor results:
Could this be a bug in the window ID's exclusively?
Mark Moscrip
Yes, you are right.
In case of Window elements it does not work as one would expect.
Actually, I could not find out what the logic was when selecting Windows in multiple Walls. It just does not follow the order of selection.
I will report this to Graphisoft.
MarkMoscrip
Thank you, I hope it is easy for them to fix.
Mark Moscrip
Stress Co_
laszlonagy wrote:
Yes, you are right.
In case of Windows it does not work as one would expect.
At first reading, I though you meant the OS (it doesn't work on Macs either).
Another problem i've noticed, (when working with the window tool) Keystrokes
are not always recognized when changing the "ID Components" (in ID Format).
The work-around is to "Save settings & close" then reopen Element ID Manager.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.14.6 (Mojave)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 24 (3022 USA Full)
Hi Mark,
Good call, it is indeed misunderstandable.
I have edited my post so it is less ambiguos.
Stress Co_
Laszlo:
Is the "input" issue know to GS? It happened in earlier versions as well.
Demonstrated in this Eric Bobrow Tutorial: (at about 2:35)
How to Set Door & Window IDs Quickly
They will now be able to see that it indeed worked in AC16.
MarkMoscrip
That Bobrow tutorial is in AC14.
The EIDM for window ID's doesn't for for 15 and up..
Mark Moscrip
You need to remove the "Element ID" from the criteria otherwise it will use the existing order of the IDs when renaming them.
Versions 6.5 to 25
MarkMoscrip
Thank you Barry,
That was it.
Mark
Mark Moscrip
Michael
Great tool in ArchiCAD, glad I saw this thread !
Michael |:-)
AC 4.5 - 19 Build 3003 Full USA
Mac OSX 10.10
