AC18-date of issue
Stephen Dolbee
In AC17 and prior, "date of issue" could be found under File/Info. Does anyone know where it is in 18? Something to do with revision manager?
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
5 REPLIES 5
Stress Co_
I'm not up to speed with revision manager,... but you could re-create it by using the "add" button.
It'll appear in your auto text list.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Eduardo Rolon
This one?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
James B
The default Date of Issue in Project Info was removed due to the new Revision Management features. Any existing Date of Issue will be converted to a custom field and its data is retained. As mentioned, you can easily add a custom field.
James Badcock
Graphisoft Senior Product Manager
Stephen Dolbee
Thanks to all. Now to check out Revision Manager.
ArchiCAD 18 New Feature Clips, Revision Management Playlist (46 clips):
https://www.youtube.com/playlist?list=PLnXY6vLUwlWVakX9gE_4eau0ClfPX1z8b
