AC21 - section marker heads not returning Layout ID
Scott Bulmer
Greetings, for all available section markers, under the Section Settings DB I cannot get either the Drawing ID nor the Layout ID to automatically show in the marker head. The are both greyed out. Note that the drawing of those views are placed on layout sheets. Anybody else experiencing this problem? Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Eduardo Rolon
Check that under General the marker is not set to "Unlinked" and that the next setting is set to "First Placed Drawing".
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Scott Bulmer
OMG, thank you so much. I looked in all the wrong places.
