AC22 - How to make "new" and "existing" in elevations read as shown in image
rob2218
So..I need to use the Renovation Filters (or Over-rides) to indicate the "new" and "existing" as shown in the image.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
7 REPLIES 7
On your Renovation Filter Options, go to "Graphic Override Rules..." (lower right corner), then highlight "Existing Elements". Criteria = Element Type is "All Types" and Renovation Status is "Existing". Check "Fill Type", highlight Surface Fills and select "Air Space" fill. This will change all surface fills to blank for Existing elements.
Really, Rob, it's time to put in a little educational investment into how to use Graphic Overrides.
Richard
AC26 (since AC6.0), Win10
rob2218
Wow...thanks Richard.
I’ll give that a try.
And you are correct, I do want to put in some educational investment in more Archicad training in general....but, geez I just can’t see myself forking out $750 each time GRAPHISOFT puts on a training session or each our local reseller want to do some in-house training. That’s a lot of pesos for a one man shop....but you are right...I need to do some more “leanin’” on this subject.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Richard, that worked, better, but how do I get the “new” to display it’s surface hatch and “not” display a solid grey tone?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Got it...never mind.
Wow...now that’s fantastic.
Thanks Richard.
i>u
Edgewater, FL!
SOFTWARE VERSION:
You just need to watch the FREE videos on GS's channel on YouTube. (Probably a bunch of independent ones are available, too.) The investment is only one of time.
Richard
rob2218
Well heck...that’s even better still.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
Regarding training, if you are on the yearly update subscription model here (Netherlands), training is free to attend with several dates available to sign up for or you can download the materials and follow along with a webinar.
Sounds to me like your reseller needs to shape up a bit with customer service
It does take about half a day each year to go over the new functions and while the youtube videos are great for a bit more in depth look, some of them don't really go over explaining the WHY of things.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
