Document & Visualize forum
AC23 Stair display up/down text?
Hi Folks,
I'm struggling with getting the stair to display its text in the desired manner.
Bottom of stair should have an arrow pointing up, on its home story. It ends with a break line.
Top of stair on story above, the stair should have an arrow pointing down, with the word down. Then entire stair should display, because its open to below/there is no other stair going up.
I can't get the text to display no matter what i try. Built in walking line or Walking line 23.
Is it just me, or is this a known problem.
Thanks and stay well.
I think that the inability to control the stair by a normal user is a known issue.
Richard
AC25 (since AC6.0), Win10
Richard wrote:
I think that the inability to control the stair by a normal user is a known issue. :wink:
True, there are many settings in many places and it all gets a bit confusing.
However what Nathen is after is the option to reverse the walk line above the relevant storey.
There is an option to reverse the line in the hidden section too if the line or the hidden section is displayed there.
The text also needs to be altered.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Rene Pahlavan
For some reason I cannot get the up/down text to behave properly anymore. I would like the text to say up on the bottom level and show hidden lines for where the stair ends. However, the down text also appears on the bottom level of the floor plan and I do not want this (turning the text off then also turns it off for the upper floor plan, and this is not desirable). Can anyone help? Never encountered this problem with stairs in the past and extremely frustrated that I cannot get it to look how it should. Screenshot attached showing the 'DN' appearing when it shouldn't on the plan.
AC25
macOS Monterey V12.0.1.
MacBook Pro (16-inch 2019)
2.6GHz 6-Core Intel Core i7
Radeon Pro 5500M 4GB | Intel UHD Graphics 630 1536 MB
Labels
