Document & Visualize forum
AC23 door & window labels
Does anybody know where the setting to turn off or "hide marker on plan" for door & window labels has been hidden?
It used to be under: Marker symbol & text >Marker geometry in AC22
4 REPLIES 4
Eduardo Rolon
It is under Model View Options.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
But that covers the whole plan, on alteration & addition projects I need to have existing window labels not showing & new showing.
I will have to use the renovation filters I suppose.
Rogerdodge:
Door Settings > Dimension Marker > select "No Marker" in the pop-up.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.14.6
Eduardo Rolon
Also. If you want more control with the door labels you can use the regular label tool and layers to turn some of them off.
OS X 10.XX latest
AC25 US/INT -> AC08
Labels
