AC23 door & window labels
Does anybody know where the setting to turn off or "hide marker on plan" for door & window labels has been hidden?
It used to be under: Marker symbol & text >Marker geometry in AC22
4 REPLIES 4
Eduardo Rolon
It is under Model View Options.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
But that covers the whole plan, on alteration & addition projects I need to have existing window labels not showing & new showing.
I will have to use the renovation filters I suppose.
David Maudlin
Rogerdodge:
Door Settings > Dimension Marker > select "No Marker" in the pop-up.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Eduardo Rolon
Also. If you want more control with the door labels you can use the regular label tool and layers to turn some of them off.
AC27 US/INT -> AC08
another Moderator
