Document & Visualize forum
Aerial Site Plan
Lingwisyer
Champion
Hi all,
I am wanting a create a Site Plan with Shadows on an Aerial Photo mapped over terrain. The only issue is that you cannot get textures within 3D documents (prior to 25?) or scale axonometric views...
Ling.
AC22-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200 RIP PSU
Win10 | R5 2600 | 16GB | GTX1660
Mscott
Bit of a long winded process, but you can do the below which may help:
Place the photo onto a floor plan
Open the 3D View, go to the View Menu > 3D View Options > 3D Styles, set the 3D Engine from OpenGL to Vectorial Hatching and close the dialog
Navigate to the View Menu > 3D View Options > 3D Projections click the parallel projections button and set your camera to a top down view, set the sun to the desired position and click OK
With the marquee tool draw around the model and then press CTRL+C a dialog will appear asking what you want to copy, in my case I selected just shadows (Edges and Polygons) also ensure that it's set to scaled drawing at the top: Screenshot 2021-12-15 at 16.14.17.png
Go back to floorplan and paste it (CTRL+V) and the shadows will appear something like this:
The elements that are pasted are fills which you can modify the colour of if you wish.
This is the first reason that would be relevant to me that I could see justifying an upgrade unfortunately one item versus the amount of work you might not quantify when you crunch the numbers
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Labels
