All in one layout
Hello to all,
I am wondering if there is a way to put all layouts in one single grided layout? actually I already can do that (grided master layout) but we can't put layout in the layout so I have to put my saved view points in that layout and I have to copy my designed information table to each grid but the problem is that I have some auto text information in that table like scales or view names and etc... and thats repeating the same info for all.
I don't know if I could explain correctly or not.
Podolsky
Ace
You need one long sheet of paper with all drawings on it, right? In Israel it called “garmoshka”. And the problem you have is title blocks. You can do this way - save all separate layouts as PDF files and place PDF files to one big layout.
Thanks for the tip, yes thats exactly what I want to do but I want them to be updatable with the view map.
