ArchiCAD 21 Labels text jumping
fuzzytnth3
Anyone else seeing this behaviour in AC21?
This happening with ArchiCAD's Elevation Label 21
Then if you select all labels opening the settings and just click OK it fixes the labels
https://www.dropbox.com/s/fvqoi89ng8dk6fn/beforesettings.jpg?dl=0
https://www.dropbox.com/s/t84jdi2dzx0r6dw/aftersettings.jpg?dl=0
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
11 REPLIES 11
Minh Nguyen
Hi Luke,
Thank you very much for your report and I am very sorry about the issue!
This is a known issue with Archicad 24 (please refer to it as DEF-3025). It is an issue with the Pointer in Label Tool when there is an Autotext within the Label Text with these Pointer Settings :
-"Middle Pointer Line Connection"
-"Connect Label to First Row" or "Connect Label to Last Row"
On the Layout, after placing the view with the Label, the results are incorrect, as the Pointer of the label isn't centered on the top line of text as it was supposed to.
Unfortunately, there is no target date set for this issue yet. I will add your request into the report, hopefully, it will receive a higher priority for fixing.
I am very sorry for the inconvenience, and thank you very much for your understanding! Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
lukegolesh
Ok, thank you, I appreciate it.
Archicad 24
macOS Catalina Version 10.15.5
Macbook Pro - 2.3 GHz 8-Core Intel Core i9
Graphics: AMD Radeon Pro 5500M 8 GB
Intel UHD Graphics 630 1536 MB
