It sounds like you have associative labels - grouping has nothing to do with them, only static elements. It is the same as deleting a wall that has associative (dynamic) dimensions - the dimensions will go away when the wall is deleted. Copying/pasting associated elements - such as labels or dimensions - gives you static elements...which will have no relation to any other elements. Typically, a risky thing.
It seems (?) that your labels were somehow all associated with the wall that you deleted. Hover you mouse over a label, and if it is associated with that wall, the label AND the wall will be highlighted (default blue). This hasn't changed in years.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
