Visualization
ArchiCAD perspective cameras
- Was there a way of moving around in 3D and when you like what you get saving that by creating a new camera?
- Once I place the camera nothing seems to be stretchy in the floor plan --I can only drag the whole thing but cannot drag the target relative to the viewpoint, change the camera angle, etc. Again, was there a way of doing is or I am just mixing up with Artlantis?
Use the secret little triangle on the 3D navigation palette. The camera tool (not VR object or scene) has to be active for it to appear.
It should stretch regardless of the tool selection. Check the pet palette.
Whoa, great.
I had no idea. Thanks.
In the 3D window, get the view you want & click on that little arrow or triangle at the top right and "put a camera into the path".
Will use this a 1000 times!
