Instead of Publishing as a BIMx Doc file you can view your model in the 3D window then FILE > SAVE AS a BIMx file.
Just change the file type to BIMx.
This will give you a standard BIMx file that you can open with the standard BIMx viewer on any machine but it will not have the PDF docs with it - only the Publiser does that.
From the BIMx viewer you can now just save the file - there is no such thing any more as a Windows/Mac/iThing version.
The file no longer contains the built-in executable viewer program - you have to download that separately for each system you want to view the file on.
