Archicad 25 Length Error
resulaslibay
hello, I would like to ask for your help and opinion regarding the problem experienced by a user.
For example, when we want to drag an object 350 cm, Archicad do it 350,  and deletes the number 3 and applies the process as 50 cm.
or we want to draw a wall 680 cm long. but it removes the number 6 and treats it as an 80cm long wall.
This problem is experienced on mac device.
Thanks for your help
I am assuming you have Ventura operating system?
If so, it is a known problem with Ventura.
https://community.graphisoft.com/t5/Setup-License-articles/macOS-13-Ventura/ta-p/359447
Djordje
Ace
as always, include your Archicad version and build, as well as the base computer specs, in your signature...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I haven't noticed this issue in AC26 on Ventura but I do have my tracker set to always on, so not sure if that may affect it.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
