Visualization
Archicad 25 interior sink bowl to twinmotion material issue.
jmaul01
Anyone experience this problem and a have a solution or work around.  Interior of the sink bowl goes missing in twinmotion.  No SEO on the sink and the sink and cabinet base, which is a slab, intersect one another.  Archicad 25 Sink object.  Can't control inside of sink material in Archicad or apply a material to the inside of the sink in Twinmotion.
Thanks,
Jim
Windows 10.
Archicad 25
Twinmotion 2022.1.
I don't use Twinmotion enough to remember the correct terminology.
But I think in Twinmotion you can set a material to be double sided - or something like that.
Nailed it Barry!!! Thanks so much.  Just getting in to twinmotion as well.  Thanks again. Jim
