SOLVED!
Archicad 25 trial saving as Archicad 24 file
stefan 990
Hello,
I am using Archicad 25 trial version, and I need to save .pla file to Archicad 24 version, but can not find option to save it 24 in File/Save As. Is this because of trial version, or is it done differently in Archicad 25?
Thanks
1 ACCEPTED SOLUTION
Solution
Eduardo Rolon
Trial versions can only exist on the computer that it is original installed and files created with trial versions can only be opened by that particular trial. Based on that you will not be able to save-as to another version.
If you buy AC you can install any version that you need so saving to 24 or just working on 24 is not an issue.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
1 REPLY 1
Solution
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
