Archicad 26 : Zoom Centering
Joe Moss
I'm having three possibly interconnected issues with Archicad 26:
  1. The zoom function (Magic Mouse zoom) get’s weird occasionally - I notice it seems to occur after editing text in a drawing.  Instead of the zoom centering around the cursor, it seems to go diagonally.  Hitting the F3 key twice (desktop zoom out - then back in) fixes it, but only temporarily.
  2. The drag function also seems to get locked up sometimes (I don’t think it’s a snap issue) - also after editing text…maybe.  Same fix with a double-hit of F3.
  3. The selection (Arrow) tool occasionally gets locked into Inject Parameters mode.  Escape does not work to switch the mode back to Arrow as usual.
MacBook Pro M1 Max 32GB : Monterey 12.6 : Archicad 26 Build 3010
20 REPLIES 20
Eduardo Rolon
Check that you are running the latest version 4004? since it fixes some of those issues.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Unfortunately things are still unstable in 4004 Preview.
👍 That is why I wrote "some"…
AC27 US/INT -> AC08
another Moderator
Frillex
Same problem om my mac.
The "fix" is to change view.
But it happens quite a lot when working with the text tool.
/Felix
AC 26, OS MONTEREY
And i don't use magic mouse.
/F
AC 26, OS MONTEREY
James B
If anyone has a stable way to reproduce the issue with zoom not following where the cursor is, please let us know - any additional information can help. We are aware of the issue and have been trying to gather more information through our technical support channel.
Thanks.
James Badcock
Graphisoft Senior Product Manager
All I can say is that it happens very often when working in worksheets.
/F
AC 26, OS MONTEREY
If there's any further details let us know.
For example, is this after switching between applications, what keys are being pressed, and what are you doing in Archicad before/after switching between applications.
James Badcock
It has nothing to do with switching applications, that's not the case for me at least. It happens seemingly at random. I can add that it's linked to our migrated projects. So far this has not happened when working in a "pure" AC26 project.
/F
AC 26, OS MONTEREY
