Document & Visualize forum
Archicad Image texture fills ACAD 25
Nicholas Jones
Hi all,
Has anyone been using the new image texture display for elevations in 25? I love how they look, however
I have been having endless problems with them and would appreciate some tips..
firstly, the PDF file sized are enormous for larger projects, I have resorted to creating worksheets of each elevation in order to be able to open them in Affinity and rasterise them, Affinity stalls otherwise!
Now I'm having an issue where they won't even export correctly, (see image)
Any ideas on what could be causing this?
ExportExportOn layoutOn layout
AC24 solo UK • 2017 MacBook Pro 15" 2.9GHz Quad-core i7 16 gb ram
OSX10.15.5
Mscott
When saving a PDF via File Menu > Save As, click on the Document Options button followed by PDF Options and see if the option Limit image resolution to is checked. If it is uncheck it and save a new PDF and check the result.
5 REPLIES 5
Nicholas Jones
Another
Tried another without shaded shaded surfaces. this is a PDF of a worksheet view placed on the layoutTried another without shaded shaded surfaces. this is a PDF of a worksheet view placed on the layout
OSX10.15.5
Mscott
This worked! good shout
Funny this didn't cause the same effects on other files.
OSX10.15.5
Vinicius Guedes
Hello, @Nicholas Jones
Are you using the default texture images, from the Ac 25 Library?
Thanks for the response! for the record these were native textures.
OSX10.15.5
