Find the next step in your career as a Graphisoft Certified BIM Manager!
Project data & BIM
Archicad schedule cells adjust to text
ananas
Is it possible to set Archicad Schedules in a way that the cells extend automaticly, so that the text is readable?
I can do it manually, but the schedule is long.
Thank you!
Eduardo Rolon
Like this?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Like this?
AC27 US/INT -> AC08
another Moderator
Yes, perfect thank you!
