Archicad
Raido
Hi, I'm a novice Archicad user. Please give advice on where to learn how to make a plan out of your drawings
Rubia Torres
Hi Raido,
Thanks for your question. You are welcome to join us in the Graphisoft Learn portal, where you can find free courses to help you improve your skills in Archicad. Please check out this course: Get Started with Project Documentation in Archicad. You will learn exactly how to get from a finished 3D model to a set of annotated PDF documentation.
Nonetheless, you might be also interested in the following links I've collected:
Where to Learn Archicad?
Archicad Quick Tour Series
Archicad User Guide: Documentation
Youtube tutorial: Layout Book
Youtube tutorial: Publishing
I hope these resources will help you. Let me know if you have further questions.
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
1 REPLY 1
Rubia Torres
Hi Raido,
Rubia Torres
