Archiframe element sorting by ID/Cnc label in column format
project
I am making a custom dimension drawings/element list with the help of Archiframe planks. I started modifying the ArchiFrameBlocks.xml and using the 'All parts to single frame single column' I got pretty close to my desired result, but i can't figure out how i could sort the list by the CNC ID code or just even ID. I'll attatch an example, and it looks like its sorting the list by length or element ammounts.
Ideally i would like the list to go from top to bottom.
101
102
103 etc
Any suggestions are much appreciated
Seems like this is a pretty specific add-on by a third party?
If so you might find it better to contact the developer of that add-on.
Also please title you post posts appropriately - not just "Good day!".
That means nothing to other readers searching through this forum.
I have re-titled it, if you want it to be more specific, please feel free to edit it further.
Thank you for the reply, Barry. I'll be more specific next time.
project
 Yes, it's a third party add-on.
