RWARCHPC wrote:
Thanks for your response. I have already set the decimal place number to zero but have not seen the expected results. I do not know what a "dimension set" is.
No it is not in the calculation units.
It is actually considered as a dimension as Braza mentioned.
Braza wrote:
this is controlled by "Dimensions..." (Menu>Options>Project Preferences>Dimensions...).
These dimension preferences are saved in a dimension scheme.
You can save as many of these schemes as you want and can apply them to each of your views - just like layer combinations.
But make sure you 'Save As' the dimension scheme that is being used in the view that shows your fills.
Type in the exact scheme name and you will be prompted to overwrite it.
Unfortunately there is no override or update option for the scheme - you have to 'Save As' with the same name (or create a new name).
