runxel wrote:
Just try this one out, Barry:
Create a new fill with area text.
Make a copy.
Rotate one of the fills: the text will rotate accordingly.
Now change one of the fills, e.g. split it in half.
Rotate the fills: the text will only rotate on the fills which were not altered.
Once the text has decided to not rotate anymore you can't get it back working. Injecting from a sanely fill won't work neither.
I see what you mean when I split the fill then rotate the plan or just the fill.
The text will always reset back to zero.
If you manually set the angle of the text to any figure then back to 0° it will rotate with the fill again.
If you use the 'Revert to Automatic Position' button it also resets the angle to always be 0° and it will stay at 0° when you rotate the plan/fill.
When you split a fill it obviously uses the automatic position to place the new text.
When you place a fill with are text on, you nominate where the text goes so it is not using the automatic position.
Just dragging the text does not break the automatic position with regards to the text rotation - you have to manually change the angle and then change it back.
Seems a little buggy but logical at the same time.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
