Visualization
ArtlantisROut plugin only works on some machines
I've signed up with Artlantis to see how "R" treats me. I've always liked the speed and results of Artlantis 4.0, but thought the interface should be in a Museum of Pain. I'm hoping "R" has addressed some of that (it looks like I can describe position in feet and inches...good start!)
I've put what I believe is the correct plugin (ArtlantisR_Out) into the ArchiCAD 9:Add-Ons:Import/Export folder on two machines. One machine allows me to save in ArtlantisR format, the other doesn't. To troubleshoot the bad machine, I made sure ArchiCAD 9 was current. Now it is; no change with respect to the problem.
Also, when I do save out to ArtlantisR format, do I no longer get options having to do with reference files? Did workflow moving model changes from ArchiCAD to an existing Artlantis project take a step backwards?
Thanks.
16 REPLIES 16
Djordje
Ace
The PlugIn is at the Art•Lantis site in the download area. The installation is semi-manual. Be sure that you replaced the export dll of the original Graphisoft PlugIn.
No, it has not. Now you do it in Art•Lantis - Open with reference. Check the Tutorial movies on the Art•Lantis web site.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I can't seem to use my Art*Lantis R anymore either. Not since I upgraded to 2219.
I have tried everything I can think of. Can't make it work.
I have just been hoping that 10 will get here soon and I can fix it then.
I need to do some rendering to day if possible.
I guess I could try to re-install 4.5 and the onld add-on.
Anyone else having this trouble?
Djordje
Ace
Did you re-install the plugin? Maybe the update wrote the Graphisoft plugin over the Abvent plug in?
Works for me nicely ... it is chugging on in the office (I hope 😉) and I am going for meetings ...
Djordje
HP Omen
I think it is because there is no add-on for ArchiCAD 9 to R1.1
9 to R yes. 9 to R1.1, no?
It could also be that 2219 and R1.1 are not working together.
Can anyone confirm that it works? (2219 and R1.1) ?
Thomas Holm
R is the same pain, just different. And NO documents!!!! Abvent has been the same since 1985. Good software, bad support. But the forums are helpful. Especially Krippahl! And the results are worth the money!
Scott Bulmer
We too have had intermittent problems with the Artlantis R out from Save As menu. Works sometimes, NOT at other times. When it doesn't work (and I have no explanation why) we 'save as' using 4.5, which seems to work fine. Aside from some quirky problems that come up from time to time, we are extremely happy with the program. Very easy to use with stunning and quick results. Using Artlantis R V1.1.0.12 with AC9 2219.
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Ok. I found my old add-on for Art*Lantis 4.5 it works fine with 9 (2219)
I still have to save as a 4.5 and then open in R1.1.
no biggie i guess.
Download the Export plug-in from ArchiCAD 9 to Artlantis R at :
http://www.artlantis.com/download/update/index.php?id=381
Regards
Pierre
Been there, done that, Pierre.
Notice that there is no Exprot plug-in from ArchiCAD 9 to Art*Lantis R 1.1
Only to R.
