Automatic Dimensioning on Curtain Wall Does NOT work?
Hi all,
I have a curtain wall on plan as attached. This curtain wall has main and distinct panels (shown as black and clear on plan). I have tried to automatic dimensioning all the panels (on plan view) but it only dimensions the overall length and ignores all the panels.
I try with a fresh and default CW then it works.
Does any body know what is wrong?
FYI, it is on AC 20
Thank you
1 REPLY 1
Automatic dimensioning works before customizing the curtain wall
If you customize one of your panel that mean you decided to create your own dimensions
Do you customize dimension or delete a curtain wall element ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
