Thank you Stuart for the quick reply.
- AC18 and CineRender
- No lamps or Sun object. Just Global illumination.
- Diffuse Depth 3 , Primary Intensity 145, Secondary Intensity 145, Sunlight Intensity 175, Illuminating Surfaces 20,
- I have never used a marquee to define a selected area to show in 3D. The model has this very light on the exterior surfaces. Strongest in similar corner.
I have tried to adjust most of these and no luck. If anything comes to mind, I would really appreciate the help. - Jakub
