Can I apply a Schedule format style to other?
ZuMedeiros
I created the perfect schedule using the format options. How can I apply the same options to other schedules?
Thanks
Miha_M
I usually clone a "good" schedule and change the element selection criteria settings.
Right click the good schedule and select "New Schedule...". In the new opened Scheme Settings / New Schedule Scheme window select Duplicate and give the Scheme a new name. Now go and change the Scheme Settings for element selection criteria.
I don't know of any way the options could be transferred from one to another existing schedule.
| Archicad 4.55 - 27
runxel
Legend
Sadly there is no easy way, but one that is not entirely obvious:
Export both schedules as XML (from the schedules settings dialog) and overwrite the styling part taking the one from the correctly styled schedule.
Sounds scarier than it is. Good luck!
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
