2023-02-01 02:40 PM
Can I have a text value in text favorites?
Is it just how to make it in Label?
Solved! Go to Solution.
2023-02-01 06:29 PM
What do you mean by text value? I have loads of favourites with predefined text for items we commonly label such as wall ties, concrete cavity fill. We have lots of pre-defined description notes that are common across lots of projects.
2023-02-01 06:55 PM - edited 2023-02-01 06:55 PM
You can create favorites with text values in the label's favorites.
It was asked if there is a favorite character with contents such as comments in Text.
2023-02-02 02:21 AM
Text favourites do not store the actual text values, just the text format - size, colour, font, layer, etc.
Favourites for autotext labels do contain the text values as well.
If you want standard notes, have them all laid out in another file and copy & paste to your current job.
Or set up a lot of label favourites.
2023-02-02 02:36 AM
thank you so much
2023-02-02 07:14 AM
We’ve got loads of text favourites set up for standard notes that retain the text content.
2023-02-02 07:27 AM
As a label or an object maybe?
But the text tool does not remember the actual text that is typed, so the favourite can't either.
If I am mistaken about this, I am happy to be educated as to how you do it.
2023-02-02 11:55 AM
Hi Barry,
They are definitely labels.
