Can't inser new dimension point in AC 25
bgoodale
Although I had downloaded AC 25 when it was released, I only started using it this week, as I us Central Innovation Cad IMage tools in my projects, and I was waiting for them to publish their update for AC25.
In AC25, I'm unable to insert a new dimension point to an existing dimension string. I usually command click to add points, but it's not working. Nor does it work when I use the pet palette "insert new point" command.
Is this just a glitch in AC 25 and I should submit a bug report? Or is there something in my toolbox settings that is preventing this from working correctly in 25? I don't have the same issue when working in AC 24.
AC 25
WINDOWS 10
AMD Ryzen 9 5950X 16-Core Processor 3.4 GHZ
128 GB RAM
64 Bit Operating System x64 based processor
AMD Radeon RX 6900 XT
bgoodale
it appears that the issue happens when the dimension is set to "manually dimension each skin"
AC 25
WINDOWS 10
128 GB RAM
Arcadia
I don't know what is causing this for you but I can report that I can't replicate the situation myself. I don't use 'manually dimension each skin"  normally but even if I do, control click adds a new node into the dimensions string as usual.
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
