Document & Visualize forum
Can t use Ctrl+ Up or Ctrl+L
Larisk
Hi! Recently I encountered a problem with my shortcuts. When I try to change the story by using CTRL+ UpArrow or I try to open the Layer menu using CTRL+L i have to hold down both CTRL and release the first one while holding down the other CTRL and UpArrow or L. I tried looking in Registry, applying new scheme in Work Environment and I stil can't figure it out.
What's your os and computer?
I have a few third party apps from Intel and MSI on my machine and steel series keyboard. They all have their own shortcuts. And usually they override Archicad. Not that that's the issues, but I've had it happen to me several times with said items.
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Larisk
You've been right about third party apps, it was a music app that was the problem. Thank you very much! 😄
Labels
