Document & Visualize forum
Cavity Walls
Jensk
How does one draw simple cavity walls.  And once I can figure this out, is there a way to insert windows, doors and openings so that the opening is 'framed', ie. the brickwork around the window or door is actually shown..
If you are on AC24 or AC25, you can use the Opening tool to place a vertical Opening into the Wall to create the Cavities. In AC25, Openings can even have a Polygonal shape:
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
@Jensk , can you please clarify.
Do you mean how do you draw a cavity wall (as in multiple skins with an air space between them), or how to add a cavity (void) in a wall as Laszlo has shown you?
Versions 6.5 to 25
Labels
