Document & Visualize forum
Change default Zone name option set
mija
is there a possibility to change the default name settings in zone tool?mija_0-1675846443394.png
Archicad 25, build 4013
2 ACCEPTED SOLUTIONS
8 REPLIES 8
You need to edit the GDL of the zone stamp.
If the name list is not in the zone stamp object, it could be in a 'Master_GDL' file that will be somewhere in your loaded library.
Versions 6.5 to 25
Lee Hankins
Mentor
We have a Global Zone Stamp that was created by Applecore Designs which has a separate XML file that can be edited for the standard list of Room Names, I believe there was also a separate object that the stamp linked to where you could edit the list, maybe this is the same for the built in Zone Stamp?
Lee Hankins
ArchiCAD 4.5 - Archicad 26UKI Apple Silicon 4032
macOS Ventura (13.2)
Miha_M
As @Barry Kelly said, you'll need to open a library GDL file. I am using a GER library on an INT version (to translate some items into my native language) and for me it was the "Zone_stamp_macro.gsm" file which had to be changed.
| Archicad 4.55 - 26
I've found it in parameters but I can't find where i can change all the option names. Every other tab is empty? 😩
You have to find the macro. The script is in the macro as previously stated
found it. thank you guys
Aaron Bourgoin
USA version has two Zone Stamps. O! has the Room Name Dropper in the Stamp itself. 02 uses a Macro.
Think Like a Spec Writer
AC4.55 through 26 / USA AC25-5010 USA
Rhino 7 Mac
MacOS 11.6.5
And just to be a little different the zone stamp I use (well not any more with labels), has the room names stored in a 'Master_GDL' file.
The advantage of this is that it is not called as a macro from an object - it loads automatically when the library is loaded.
This means  any object has access to this parameter, just create the parameter name in the parameter list of the object, and you will have all of the room names available.
Versions 6.5 to 25
