2022-01-12 07:44 AM
A great announcement for the AEC industry:
Click on the following hyperlink to get a bigger idea about this merger: https://aecmag.com/visualisation/chaos-and-enscape-to-merge-to-form-viz-giant/
Solved! Go to Solution.
2022-01-12 08:21 AM
It is up to Graphisoft to choose the best marketing and development strategies for its Archicad software. To that end, the company must take the right direction.
2022-01-12 07:58 AM
In the last few years, after Corona renderer and Chaos Merge, we lost corona render support for Archicad,
now we can expect the same with enscape... don't forget that Chaos is a strong partner for Autodesk , Vray was created especially for 3ds Max, and now implemented to revit,
They're trying to push Archicad in the corner
2022-01-12 08:21 AM
2022-01-12 09:25 AM - edited 2022-01-12 09:26 AM
Without surrendering to your cynicism - loosing the Enscape connection would surely be a hard blow to AC especially if one considers its potential after the merger.
2022-01-12 10:10 AM
The solution is not to complain, but to innovate.
2022-01-12 06:29 PM
Actually, the Corona render support for Archicad was more a victim to the COVID pandemic lockdowns and the staff shortages it caused in a lot of industries, rather than to the buyout by Chaosgroup.
The Corona guys were already having a difficult time getting developers to work on the project and were under-staffed, and then the lockdown and the forced work-from-home situation made things worse and they had to cancel the project.
You make it sound like this was all Autodesk's doing when they have nothing to do with running that company.
You forget that Vray is also available for Rhino, Sketchup and Cinema4D - none of which are Autodesk-related products.
If the aim was to kill support for non-Autodesk related Vray or Corona plugins then wouldn't those also have been eliminated?
2022-01-13 08:38 AM
You're right, Clarence!
