Document & Visualize forum
Cinema 4D Rendering simply stops
pallsopp42
I've run into an issue with Cinema 4D rendering. Instead of building a preview of a 3D ArchiCAD window it stops after a few seconds returning a black screen. Same thing for when I ask it to render the entire 3D window.
I have plenty of RAM and a fast iMac.....
Anyone else run into this? The only thing that seems to work is quitting ArchiCAD and restarting it...which is a pain in the rear especially if you happen to have a mechanical hard drive vs. an all-solid state memory pack.
Phil Allsopp
ArchiCAD 18
OS X 10.10.1
iMac 27"
Intel 3.4GHz Core i7
AMD Radeon HD 6970M 1024 MB
16 GB 1333 MHz DDR3
6 REPLIES 6
Lasse Borg
Same here!
If I select an object, wall or slab it renders fine but as I try to render the hole scene it goes black after preparing. It never starts to calculate.
Lasse Borg
BIM-Manager/BIM-Development
Ettelva Architects
ArchiCAD 3.1 - Latest
BIM-Server - Yes
Windows 10
- I'm confused.
- Yeah, well it's a big club - we should get t-shirts. (DrWho)
Erika Epstein
Is this true for all your files or just a particular one(s)?
Do the problem files generate any errors? (turn error reporting on).
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Lasse Borg
Just the one and there are no errors!
I'm in contact with GS on this topic.
http://archicad-talk.graphisoft.com/viewtopic.php?t=47272
Lasse Borg
Ettelva Architects
BIM-Server - Yes
Windows 10
- I'm confused.
I had a similar issue recently with a slab. Though a process of elimination I found a surface that I had manipulated that was causing the issue.
Perhaps check the surfaces? That's all I've got for now mate.
MAC & PC Archicad 15 - 21.
AlWisch
Could you elaborate on this? I'm having the same issue after changing some surfaces. I've tried reverting them back to where they started and I can't seem to get it working again.
Is there a particular aspect of the surfaces I should be focusing on?
Thanks!
sampson
A ram low speed maybe an issue in regards couple with a dense vegetation landscape can stop the rendering.
