Visualization
Cinerender - polycarbonate render
I am really struggling to create a good quality render using Cinerender. I am trying to render my design which is made up of polycarbonate panels. Could anybody please help me with what would be a good setting to use to create this polycaronate effect?
Thanks,
Holly
15 REPLIES 15
Paopao
Thanks,
Holly
Have you had any luck? I have the same problem right now and I wonder how to get polycarbonate in Cinerender.
Pao
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
Too broad of a category. Can you show an example of the texture and color in the polycarbonate you need?
https://materia.nl/material/?keyword=polycarbonate&sort-order=newest
Paopao
I need to achieve exactly the same effect and colour of the picture you have posted.
Thanks!
Thanks!
not at computer now to post zip file with material. Corrugated profile is easy to get using roof acesssry tool. Convert to morph and rotate to virtical. Apply the material.
Paopao
Thanks!
Thanks for the tip. In the meantime we have decided to use a flat polycarbonate surface. Any idea on how to render the material? I don't seem t be able to find any on the net. I am trying with an opaque glass material but not quite what I am looking for.
alemanda
I've just made a simple research on google and found this
https://www.polantis.com/it/everlite/danpalon%C2%AE-opal
On the left you find the textures for each channel ...
Shouldn't be too difficult to get the desired effect
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Paopao wrote:
.... I am trying with an opaque glass material but not quite what I am looking for.
Did you try the ArchiCAD Frosted Glass material ?
Hi there - did anybody work out the texture setting for this cellular polycarbonate (e.g. Danpalon) fro rendering with Cinerender? ANy assistance/tips would be really apprecated!
Kate
Kate,
You may have to get very specific about which product and color your after if you want some help with this.
https://www.danpal.com/architects-inspiration/download-page/
