Composite Structures - error in total thickness
CarlM
I have an issue with the summation of the total thickness of a composite structure - the addition is simply wrong!
in the attached image: 13+12+120+12+13 = 170, not 169...
Is this a known error?
AC 25 SWE, 64-bit
Windows 10 PRO
Dell Precision 7530, i9-8950HK, Nvidia Quadro P3200, 64GB ram
vistasp
Had you, by any chance, typed in 12.5 for the first and last skins? Even if they shows up as a full integer (13) in the dialog box, they would be getting calculated as 12.5.
It could be any other pair of skins too...
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
vistasp
= v i s t a s p =
bT Square Peg
Yes - user error.
Check and type the thicknesses again.
If you have 11.7 it will round up to 12 if you have the decimal precision turned off.
So you may well have some slightly smaller thicknesses there that you aren't noticing.
See my images.
One is correct but the other I typed 11.7 and 12.7 - they still show as 12 & 13 but total with the correct figure of 169 (actually it would be 168.8 but will round up to 169).
CarlM
vistasp and Barry,
You were both right!!
Thanks a lot for such quick replies!
I retyped the thickness for each and one and the math adds up again - tricky little round up that has caused me quite some headache.
Thanks again!
AC 25 SWE, 64-bit
Windows 10 PRO
