Composite wall shows differently on plan view and section view
adzik
Problem:
I have Composite walls (a lot) in the project. On plan view the walls outer lines are a thick black ones like it should be. Hit F6 and in Section view the wall outlines are slim gray.
Don't have any graphic overrides or such enabled (checked twice )
Any ideas?
Regards.
Running ArchiCAD 23 INT.
1 REPLY 1
Did you check this screen option "automatic adjustment visibility pen colors for model views" into your work environment ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
